Is that @MiniMike20's JCW?
Of course it is.Is that @MiniMike20's JCW?
There's another reason people don't remove them...I didn't remove the original ones because my car was still under motor plan...so I bought real cf ones and stuck them on. 😁agree, it doesnt even feel nice imo...
*i test fitted it once and was like nope.
but then, got a set of f8x paddles atleast 1 year ago which are yet to be fitted 🫣
I believe the Yaris is quite quick...how does it compare to the others there?
Sent from my SM-G780F using Tapatalk
Use some "Huak Tua!" on itI have this on mine too, fitted by the previous owner and I also don't like it, looks cheap and feels bulky. My problem is though that I can't get them off, I have no idea what they used to stick it on there but it ain't going anywhere.
Wanna get the LCI steering wheel soon anyway then I'll just get the magnetic ones.
You mean behind...You forgot to fill AdBlueCoz that's how far ahead I am![]()
It is stretched on normal view, but if it is clicked on then it opens into the normal pic, cabbie is looking tops dude!Not sure if the picture is stretched on everyone else's side, it uploads fine, but when i save the post, on my side it gets all weird.
Did you get some Joeys wors while you're thereView attachment 25402
Took a quick snap before going white on white, it might only be temp this weekend since I can't get 763M in white for reference so no idea what it would look like.
lol Nah just grabbed some Pizza on the way homeDid you get some Joeys wors while you're there....car looking good as well!
Mine feels goodThe only good feeling and good-looking paddles are the ones that you install by stripping out and installing them into your existing module or getting the complete replacement units.
I had the former in my F10 (they actually weren't expensive) and latter in my F90 (these are the OEM ones from the CS and are now M Performance parts). The stick-on ones I have felt before seem like they are going to come off unless you're pulling them around the stock positions 🤦♂️
Man, the cluster and steering wheel looks so damn good in the later models compared to the pre-LCI. I really need to get this retrofitted asap.There's another reason people don't remove them...I didn't remove the original ones because my car was still under motor plan...so I bought real cf ones and stuck them on. 😁
Been thinking the same thing but if you get a second hand cluster the process to virginise and code it is a nightmare . Easiest way would be to get a new one from dealers and code it.Man, the cluster and steering wheel looks so damn good in the later models compared to the pre-LCI. I really need to get this retrofitted asap.
At least you have the better-looking steering wheel so you're halfway there.![]()
Sent from my SM-S911B using Tapatalk
