Magneto said:Is there anything I need to know about filling up with Diesel? Are there different types of diesel and who usually stocks them? I have a F30 330d.
A client of mine mentioned ppm and Sasol. I said HUH?
Running 500ppm on a car without a DPF delete will completely screw up the DPF. SINGH911 will confirm. 10 or 50ppm on a stock turbo diesel :coolshake:B///Moodley said:From what I've been told, 10/50ppm are better for your car and the environment but 500ppm is better for performance. I'd say just get 50ppm from a busy garage in your area as a busy garage will always have fresh fuel.
///M Power for the win...![]()
Anyone here has experienced this? I currently fill diesel at Engen (for both 20d and 30d), for the Ebucks but thinking about changing if it’s better for the car. Where’s the latest thinking at in terms of best diesel to use for BMW diesels?From what i have found...
10pp gives you the best consumption, however power is noticeably less.
I rate Shell 50pp the best for performance, however fuel gets chowed quickly.
Yip agreed, any "performance gain" would be so marginal you could never tell.IMO…
I don’t think the performance ‘improvement’ will be significant to change to another brand over convenience. Besides how is this better performance measured ?
No real difference on my X3 20d with any diesel brand and also not much difference with 10ppm vs 50ppm.Anyone here has experienced this? I currently fill diesel at Engen (for both 20d and 30d), for the Ebucks but thinking about changing if it’s better for the car. Where’s the latest thinking at in terms of best diesel to use for BMW diesels?
On my land rover discovery I filled engen and sasol but every 4 tanks I throw a bottle of injector cleaner in and iv been getting same power aswell as same consumption...when I just bought the land rover I never used injector cleaner and I found the 10ppm gave bigger power but used more fuel but not a major difference like 10km difference...after Iv been using the injector cleaner the power is proper aswell as consumption...
Yes perfectly fine.Is it okay to use 10ppm on the older diesel engines? I have a 2008 e90 320d.
