E90Francois
Hi everyone.
So to start off i purchased a E90 320d 2006 M47TU2D20 engine 2 weeks ago.
Got it for a steal, new engine fitted new turbo new high pressure fuel pump.
After about 200km the car would randomly switch off when driving.
Owning previous petrol bmw's i knew the culprit would be either crank or cam sensor.
Replaced crank sensor.... after pulling almost everything off to get there. Intake ended up not being tightened down, only one bolt holding the EGR throttle body (if you could call it a TB) loose starter even if it was brand new...
It's like they were limp wristed putting things back...
Anyway went through the entire engine tightened everything down baught new bolts and nuts etc.
The car was down on power (like very down on power) when i bought it but i knew mechanically it was sound.
Now all boost leaks are fixed pipes tightened down etc the turbo spools hard at about 1200rpm but still no power.
It has a decat gazorst but it doubt it will cause limp mode.
I ordered a INPA K+ CAN diagnostic cable with the switch but it's probably only going to arrive next year.
So i ran diagnostic with my cheepie obd2
Cleared the codes and scanner agave me the following codes that came back
P1278
P14a0
P0545
P2620
P1426
P0031
P1213
Googling gave me different results for each code.
Hopefully someone one here can tell me what these codes mean for the 320d e90.
For instance one code is for throttle body... umm it aint got no throttle body 😅 only egr.
Really want to get it sorted so i can go on holiday this December.
Not really keen to drive it 1000km+ in limp mode.
Even though im getting 4l to 100km 😂
Halp please...
P1278
P14a0
P0545
P2620
P1426
P0031
P1213
Halp please...
