Hi All,
I am looking for some help regarding the n54 rear turbo failing,
I have had the same issue for a while now and would like to know if anyone has any knowledge in this area. this is the third time the rear turbo has failed and the peak boost is set at 18.5 psi via JB4 map7 and 109 is being used. i doubt its the map if its only the rear turbo that keeps failing, can anyone assist with this issue?
