Fender Rolling
Ziyadh X5 50i
Hi Guys, I just fitted a set of Rays Engineering 18” Wheels on my 135i Coupe, the 9.5js rear touch quite a bit. Can anyone point me to a good panel beater that can roll the fenders. I’m in Jhb North. Thanks in advance Ziyadh
NBN
What is the offset of the wheels and size Tyre are you currently running. I hate to tell u this, but without running a really skinny and stretched Tyre, no amount of fender rolling will help u. 1 series cars come with very high offset wheels.
im not sure about the E82, but when i fitted the 10j rears on my E92, i had a lot of rubbing,
My research got me to a point that if i sourced the E93 Convertible rear sprints, then it would be stiffer and lift the car in the back, which it did.
Lifted the rear a good 5mm and i havent touched since.
Im not sure if the 1 series convertible is heavier in the rear that the Coupe, but if it is, then this will be an option for you.
i got my Springs from MD House in Wynberg.
Ziyadh X5 50i
Hi, sorry for late reply. The offset is 35. I”m currently running 235/30/18 front and 265/30/18 in the rear
interesting info, thanks man
