Update.
Went on a breakfast run today to Magaliesburg. Some interesting observations on this car:
- I learned that you can keep the car in Sport Plus, but switch the adaptive suspension to comfort (standard). This gives a forgiving ride, but keeps the gearbox and engine in the sportiest setting.
- When the car is in Sport Plus and gearbox in automatic mode, even with partial throttle engaged, the gearshifts are brutal. Brutal in a great way. Each gearshift thumps through your back, quickly and forcefully. I drove the car most of the way with the above settings on and it was a brilliant experience. You want to hit the red line and feel each gearshift whack your back (you feel it in the seat and through your spine).
- The car vibrates a bit when pushing on, even with the adaptive suspension in standard mode. The rear end is planted, but the engine sends tremors through your seat and the body shell. More so with the sports exhaust on. I was told that this is normal, but will check it out when the car is next booked for a service. This did not impact the handling though.
- The ride quality on these 20 inch wheels, non RFT, and adaptive suspension is quite good. I did the same route in my 320d F30 (18 inch RFT) back in early 2018 and it felt about the same as my Cayman now. For the record, my Boxster (19 inch and adaptive suspension) felt softer than both these cars.
- Even though there were quite a few, fairly large, speed bumps, the car did not touch or scrape these. The approach angle is pretty decent for a sports car.
- I always put the Auto Stop Start off, because it is annoying in traffic. However, out on the open highways, if you switch it on, it engages coasting mode in 7th gear. Basically, this puts the car into neutral. I used it on the N14 and it did improve fuel consumption. My average for the trip was 10.3 litres per 100km, that is with hard driving on secondary roads. Overall average, since buying the car, is sitting just under 14 litres per 100km. I will use the coasting mode on my highway drives more often.
- I had a run against a 981 Cayman GTS (same 3.4 as mine, but with a small bump in power). The gap was not that great against my 981 S. However, a base 718 (2.0 4 cylinder turbo) whipped us both in the short sprint stakes (did not have much opportunity to push it to insane speeds though, where the NA 6 would likely crush the 718 turbo 4).
I met a few guys who are planning some legal drags soon among the Porsche community. Would be keen to assess the car's performance under those controlled conditions.
The breakfast run allowed me to push this car harder than before and I can see that there is more to this car. Will be keen to take it to the track to properly open her up.
(Update: I have booked the car in this week to check the vibration issue. Best case, it could be a rear wheel balancing issue. Worst case, it could be an engine or gearbox issue - some say the active mounts on the gearbox, as part of the Sports Chrono package, give up over time)
