T
TheFlash
reacted to
Clint@MMS AUTO's post
in the thread
with
Like
TODAY’S UPDATE - REAR SUSPENSION REFRESH In my attempt to constantly make some kind of progress on the car whenever I get a bit of...
Oct 4, 2026
N
NBN
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Ten - Assembly Clocking rings and the separator for the oil ring. Unpack the wrapped block Unwrap the cleaned crank I...
Oct 4, 2026
T
TheFlash
replied to the thread
technical
Chapter Twelve - Engine and Gearbox Back In After giving the engine bay a good cleanup, the engine was dropped in with the gearbox...
Oct 4, 2026
T
TheFlash
reacted to
Peter@AEW's post
in the thread
technical
with
Like
Bravo! Big End Bearing clearance is 0,030 to 0,070 typically so you are mid point which is excellent. Looks like a solid build!
Oct 4, 2026
T
TheFlash
technical
Chapter Eleven - Engine Timing and Getting Final Items Wrapped Up The plan was to get everything close to lined up and finalise in the...
Oct 4, 2026
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Six - Rings, Bearings, Oil Pump etc. Since the rings were the source of trouble since new, I was determined not to use the OE...
Oct 4, 2026
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The 5th Gear Lean This car came equipped with the five-speed manual ZF gearbox; at some point in my ownership of over 20...
Oct 4, 2026
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Four - The Engine Teardown Vanos Removed The dual mass flywheel wasn't in bad condition but LUK clutch and flywheel...
Oct 4, 2026
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter One - Tools to remove the engine Bolt-on supports for the jack stands; these help secure into the factory jack spots and safely...
Oct 4, 2026
R
raks16
reacted to
TheFlash's post
in the thread
technical
with
Like
This is going to be a journey. Was originally intending to do some basic maintenance on my 2002 E46 330i. The original list - Sump...
Oct 4, 2026
Peter@AEW
technical
Oct 4, 2026
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Oct 4, 2026
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
Chapter Nine - Measuring Things Main bearings measuring right in between tolerances The big end measured fine as well...
Oct 4, 2026
msm
reacted to
TheFlash's post
in the thread
technical
with
Like
Oct 4, 2026
MLorgat
THIS IS MAKING ME WANNA DO MY SHOCKS NOW.
Oct 4, 2026
