MLorgat
reacted to
Clint@MMS AUTO's post
in the thread
with
Like
TODAY’S UPDATE - REAR SUSPENSION REFRESH In my attempt to constantly make some kind of progress on the car whenever I get a bit of...
Oct 4, 2026
T
TheFlash
replied to the thread
technical
Chapter Ten - Assembly Clocking rings and the separator for the oil ring. Unpack the wrapped block Unwrap the cleaned crank I...
Oct 4, 2026
T
TheFlash
technical
Chapter Nine - Measuring Things Main bearings measuring right in between tolerances The big end measured fine as well...
Oct 4, 2026
T
TheFlash
technical
Chapter Eight -The Cleanup and Cylinder Hone Start cleaning the crankshaft and oil squirters Once the varnish is removed, the crank...
Oct 4, 2026
CK4LIFE
reacted to
in the thread
with
Like
Oct 4, 2026
T
TheFlash
technical
Chapter Seven - Vanos I looked around a bit and did end up with a seal kit from Beisan Systems, I didnt have any rattle issues so...
Oct 4, 2026
S
Stephan22411
reacted to
naeem9's post
in the thread
discussion
Walnut Blasting Gauteng
with
Like
Yosh at Dark Artz Performance in Jet Park offers this service the quality of his work is exceptional.
Oct 4, 2026
Peter@AEW
technical
Excellent choice the B30 is really an engine that can accept mods easily. Xceede may be able to assist in a better tune for that engine...
Oct 4, 2026
Peter@AEW
reacted to
TheFlash's post
in the thread
technical
with
Like
I ended up doing CAMs too, it's going to need a tune to get the benefits though
Oct 4, 2026
T
TheFlash
reacted to
AdiS's post
in the thread
technical
with
Like
Agree! Thank you for delivering high quality content to the forum!
Oct 4, 2026
T
TheFlash
technical
Oct 4, 2026
T
TheFlash
technical
Chapter Six - Rings, Bearings, Oil Pump etc. Since the rings were the source of trouble since new, I was determined not to use the OE...
Oct 4, 2026
T
TheFlash
technical
Chapter Five - The Head I see some suggestions, so I will get to it, the head was gas-flowed with CAMS, all done by Vanderlinder...
Oct 4, 2026
T
TheFlash
technical
Chapter Four - The 5th Gear Lean This car came equipped with the five-speed manual ZF gearbox; at some point in my ownership of over 20...
Oct 4, 2026
Peter@AEW
reacted to
in the thread
with
Like
Oct 4, 2026
