anile8-zn said:tashen , a gain on the motor is not a gain on the wheels
for example
my brothers bone stock z4 made 241kw on the motor at bimmerworks
then we changed it to wheel reading and it read 180kw
this was 4th gear , 3rd gear read less.
my point is hyper power can show both readings
u need to take out drivetrain loss too see wheel power.
come now u arent that dense
if u claiming flywheel power in hyper power dyno's to be wheel kw
then i made 306kw there on my 335i , then i hold the record for the strongest 335i ever in dbn
Tashens' stock and chipped runs were done in the same gear, as can be seen by the duration of the runs. His wheel power gain was 21.9kw. But Zeemax printed the flywheel reading as per normal.
