x3 rear prop shaft reconditioning
Idany
Hi all,
I've been hearing a metallic clunk on my x3 whenever i would pull away and I've always thought its the rubber coupling at the back of the propshaft. Today the mechanics took it off and found that its actualy the u joint on the front of the shaft. BMW wants 13k for a new one :dunnoanymore: Does anyone have an idea where i can take the propshaft for repairs and balancing in Johannesburg?
AndreX
i Would Def recommend ZF in medowdale speak to nico or hardus they will be able to source a part for you and their service is amazing
Hope this helps. :thumbs:
Waseem 333i
Does your mechanic not know who to take the prop to for repair?
I remember seeing a post on a gut who does propshafts at a place called mayfair gearbox. Please search the forum to find that thread.
AdiS
Well I'm not sure about the X3, but I know on E46 it's basically impossible to repair failed U-joints in South Africa, because it requires specialist equipment that no one has. So you might need to pony up for that new prop, or find a used one from a scrapyard that is still in good nick.
Waseem 333i
I broke the rear joint on my e46 prop. It has a cv joint for the last one. Replaced that with a new carrier bearing and balancing. Its all good.
AdiS
The rear CV joint is replaceable, but not the U-joints.
Idany
Thanks for the reply AndreX. I called ZF and spoke to Hardus. He gave me a number that i can call for a used part. Still trying to reach the guy no success yet
Idany
Today i called Propshaft Balancing Cv Centre in Rooderport the lady i spoke to said they can do it, i am not convinced but i just wanted to go satisfy my curiosity. I also called Tri Torque in cape town and they said they can do it. Problem is getting it there.
At the moment it looks like it might just have to hunt for a used one in good shape. Any leads?:fencelook:
Idany
Hi Guys,
Thanks for the lead, i finally contacted Bm spares. Happy to say i got a descent propshaft from them today for 2,5. Thank you again AdreX
Ozzycat
Hi there.
Just picked up a 2005 2.0 diesel and it had the usual clunking in the lower gears. Mechanic stripped out the rear propshaft and one UJ was totally shot. He took it to a place in Randburg who said they couldn't service the propshaft. After calling BMW and getting quoted R18k for a new one I found Propshaft & CV Joint Empire in Kya Sands.
Mario completely reconditioned the propshaft with new centre bearing, greaseable UJ's, centre bush and a new flange for R2300 all in. He also does high speed balancing. He can be contacted on 011 026 6990.
Still have the clunking though and transfer case seems OK having done a bit of trouble shooting via various forums. Tyres have even tread although they are not matched pairs. Changing the transfer box oil this weekend and will see if that makes a difference.
