Windscreen chip repair Sandton/Midrand area.
WyKiD
Hey guys any recommendations on where to get a small windscreen chip repaired in the Sandton or Midrand area. Good option would also be contact details for mobile guys that dealers use, they usually do good work.
Used the PG Glass in Wynberg a couple years back, was not to happy with the result as they drilled 2 "large" holes into the crack which remained quite visible after the repair. I know they do this to get the resin into the crack but I have seen other repairs done with more finesse and leaving a better end result.
:coolShake:
MHuzaifa
If the crack isnt bad and you dont want to replace the windscreen using cutex and leave for an hour or 2 and then wipe away using cutex remover this will stop the chip or crack from spreading lol if used this method works like a charm ...
WyKiD
Its not too bad, looks more circular than the star type cracks. Dont think it needs the windscreen to be replaced, just want to improve the appearance of the chip and reduce the risk of future damage.
Does the cutex actually fill the damaged area improving the appearance?
MHuzaifa
Well the apperance stays the same they cutex just stops the crack from damaging the windscreen further, so basically the mark remains but the cutex helps prevent the damage from getting worse ...
firaz
Hi Wykid,
Please send me a reminder tomorrow. Got a guys business card in my office at work. Used him once. Really good work and he comes to you.
Regards,
Firaz
Sent from my HTC One mini 2 using Tapatalk
WyKiD
firaz said:
Hi Wykid,
Regards,
Firaz
Thanks bud, will do so...
