Iceman12596
fredlington89 said:Your alternator, oil level sensor and water pump communicate on a BSD line. Replace your pump and your sensor will work again
Sent from my VKY-L09 using Tapatalk
So his waterpump is shot again ?
Yea. The waterpump fault doesn't want to clear so it confirms the problem.Iceman12596 said:fredlington89 said:Your alternator, oil level sensor and water pump communicate on a BSD line. Replace your pump and your sensor will work again
fredlington89 said:Yea. The waterpump fault doesn't want to clear so it confirms the problem.Iceman12596 said:fredlington89 said:Your alternator, oil level sensor and water pump communicate on a BSD line. Replace your pump and your sensor will work again
Notice the post with his fault codes it has a communication fault om the pumphusaindindar said:fredlington89 said:Yea. The waterpump fault doesn't want to clear so it confirms the problem.Iceman12596 said:fredlington89 said:Your alternator, oil level sensor and water pump communicate on a BSD line. Replace your pump and your sensor will work again
Interesting!
Didn't know the failing water pump can affect BSD interface.
Yep. OEM Pumpboost3d said:It's an OEM pump right, it should carry a years warranty at minimum, i think bmw is one year guarantee on labor and two years on oem parts.
No fan fitted in the eboxfsalie said:Yuben, that could be the ECU box fan.
YUBEN said:Is the car currently safe to drive? What warning will come up if the car overheats?
Coolant level is full.
Shuaib1 said:Can these pump fail in such a short period?
YUBEN said:Also can the JB4 be affecting anything ?
At this rate, I don't even think it is feasible to run this car on the dyno on Saturday:smashScreen::smashScreen::smashScreen:
fredlington89 said:No fan fitted in the eboxfsalie said:Yuben, that could be the ECU box fan.
