Basically the stock airbox has some baffle in it to decrease engine noise. The baffle usually consists of a pipe leading into your airbox and slightly restricting the flow of air. If you remove the baffle, you will get slightly more engine noise and a bit better performance.
If you look inside your airbox you will see a plastic pipe, just remove that.
