Well Done to Sendhur and BrandonF1 on their 1km runs
444YYY
Guys, is it just me?
But a BMW without a BMW motor should not be called a BMW :fencelook:
No offence to the owner.....
J
Josh-ZN
that would mean there is no such thing as a McLaren F1 (bmw) or a Pagani Zonda (merc) or a Ford ST (volvo - previous model) or an Audi R8 v10 (lamborghini) etc etc :fencelook:
BrandonF1
Twinz said:
Well done guys :thumbs:
Where are the pix :joy:
ODI pictures:
BrandonF1
Josh-ZN said:
wow the renault guys really like that place
Hey Josh
It was part of the RS club championship being run throughout this year. 7 events in totol. So we had a great turnout, Reno's are no known for their top speeds, but was fun non the less.
444YYY
Point taken, I was referring to aftermarket engine transplant cars..... Lol
Baracus
BrandonF1 said:
SP33DYV said:
BrandonF1 said:
SP33DYV said:
Dippies said:
The time in essence is more important i think :thumbs:
But a Good Top Speed run :thumbs:
On the 1km, speed is of the essence. Seeing that only 1 car runs at a time.
Sent on the run from my iPhone using Tapatalk 2
That is a decent run. Probably the first stock speeds and times I've seen. :fencelook:
Thanks, what do modded x35's do more or less? I expected around that speed to be honest, but was not sure what stock x35's do on the 1km.
Modded you're looking at 220-228 km/h at the 1km mark and below 13s for the 1/4 mile. Depending on traction though.
I would think the highly tuned x35's can run higher ie 235-240 ish?
I managed to run a 237 in Jan with temps at 36 degrees..also my car was not 100% at the time as the map a had loaded was a bit too aggressive for the conditions on the day. When I got home I noticed from the data logs that my timing was all over the place even with a strong water meths mix? Previously under much cooler conditions all looked fine. So lesson learnt, next time at ODI I will run a slightly more conservative map which should smooth the timing out and give me a couple of extra Km/h's up top. I know M3_Devil has also run a 237 previously at ODI and I think Sherwin did a 248 in a 135i not so long ago. However George still holds the record of 251 on the Km in his 335 with stock turbo's.
BTW 216 on the Km sounds good for a stock 135i, well done!:thumbs: ...now let the mods begin :rollsmile:
