MO@CRAZYRIDEZ said:
Kish2604 said:
Thanks for the congrats everyone...
@Mo... The car is stock other than what's listed on the first post, it's an awesome platform and the n54 responds to mods very well.
I honestly didn't expect those numbers as well, was expecting around the 250 mark but the following runs on lower maps backed it up as well...
:thumbs: Thats awsome you really have a strong car bud,
Im sure you can easily climb into to high 350-360wkw with a set of Rb's
raise:
I am sure it can most definitely reach those figures if I had the spare cash and the car wasn't my daily drive, however that's the beauty of the jb tune, just add fuel,adapt and run... When you done turn back to map 1 and off you go...
Nicbyte said:
Wow 301wkw, that's a Great number. Question, how much difference does the downpipes make with software vs just software? I'm still under MP so cant do DP's but I'm looking for good software. And What Engine is that N54 or N55?
It's an N54 motor running the jb piggyback tune, the downpipes were an essential part of the plan as it allows the car to breathe,rev and spool up better, in one of the data logs I did it took the car just under 1000rpm to spool from 0psi boost to 16odd psi, that's massive response times...
I did not dyno before so I can't tell you what the power increase was, however the torque jump was massive from stock with jb to after the dp err fitted...
