Water leak
JENICH
Heven said:
Yep. No bleeder screw.
Could be that one of your coolant pipes, thermostat or even the radiator could be leaking. Next time you fill it up put the heater on max, to check if it gets hot if it doesn't, the water pump has failed.
Hey there Heven,
Switched the heater on full go and there is heat:fencelook:
D
Dippies
Jerry is it from the pipe or the silver metal bar.
Maybe the pipe is just cracked or cut by the Clamp.
JENICH
Smartiesman said:
Hey Jerry, sorry to hear about your troubles dude. I you need any help, shout.
Thanks bud, need to carry a 2 liter bottle of water with me now:nonono:
JENICH
Update.....
Part #8 had a chunk missing after I got back from JSN and i think they deliberately broken it some more because on my way back it was pissing out.
They did tell me to come back to have the part fitted which would cost R600.
So go home and open up the covers to check. I see the piece missing and then Pratley Steel come to mind.
Long story short, and all is well again. Would still like to get the part replaced though. have a few fanatics looking out for this part
Thanks guys for all the help and support:thumbs:
D
Dippies
Glad you got it sorted
Would still recommend that you rather replace the part . :thumbs:
Good luck. :thumbs:
JENICH
Good luck. :thumbs:
Hey there Dippes,
Agree 100% it was a temporary job, busy looking for the part
Part # 11717787870
Anyone have this part lying around???
