I have a set of single vanos seals ( one teflon seal and one nitrile o-ring ) and have a slight hunt on idle with a flat spot when pulling off or at say 2000 revs .I pull the gearbox out and change the clutch all alone , but the vanos seals looks a long job as per Beisan's article (long , but good ) on the net .I must pull tappet cover off , take measurements and make a set of blocks at work...maybe then:thumbs:
Maybe take out the airbox to make space then you can take a tin of carb cleaner and spray pipes leading to the inlet manifold - the spray will be sucked into any leaking pipe or crack and the engine note will change .
If I remember correctly you may get an error of vanos mechanically stuck or so on the diagnostics if the seals are worn .Good luck .
