Hi guys I need some advise urgently pls.
About 2 months back I did an oil service on my car. the guy at the spare shop didnt have castrol oil so and said that Shell helix oil 10w40 should work fine. I've been running the car with it since, but about a week ago I noticed that on idle and pull off theres alittle blue smoke coming from the tail pipes. It doesnt smoke when i start the car, just when the engine warms up
The car runs perfectly, just the smoke. It doesnt smoke too bad but the thought of it smoking up is bugging me.
I've read that it could be the ccv(oil separator) or valve stem seals. But before I go down that road i'd like to know if a simple oil change with the correct oil would do the trick.
What is the recommended oil to use on my car?
Its a 2004 318ti (compact)
Thanks guys
Thanks guys
