My 323i has 225 - front and 245 - Rear 18" low profile (iirc). How many Km does it lasts from day to day driving and any members in JHB can provide relatively cost effective replacements? Thanks
I had a preLCI E90 320i sportpack and on Bridgestone RFT's I did 78000km on the first set. Normal driving - It was a 320i afterall..................:fencelook:
Cool no worries
Also you will see no spare wheel. What i do suggest is get a mobility kit also for the car... just in case cause you wouldnt wanna drive around on the RFT flat cause you will 10 to 1 end up replacing it so the mobility kit has a little compressor in it and tyre stuff so if it's a puncture in the middle of the tyre or something you can fix it next to the road..
Any questionws please pm me will see where i can help
The benefits of RFT technology are apparent when you replace the tyres , they are not cheap .
It would be interesting to compare RFT verses normal tyres to see which gives better life .
Good luck .
When my wife had her 323i with 18's Michelin RFT its cost around R4200 per tyres to replace :flyfun:
I had to replace 3 tyres all below 10 000km due to damage when driving on jhb roads and down to dbn:thumbdo:. After the first R4200 I decided to go second hand Michelins.
I think RFT are terrible, mine is going to 40k now and rotated them recently, back are completely worn the front still have some life but not for long.
