What tyre pressure should you have on a 135i with Stock size 18inch tyres, in this case Dunlops. Fronts and rears would be different i assume. I will be doing a long trip this week 600Km.
2.4 in the rear and 2.6 in the front is the recommended pressure if I recall correctly. Personally I run 2.4 all around for the sake of increasing comfort slightly.
please double check the pressures on your door card as I have found that 2 otherwise identical e92 335i's have different stickers on the doors, the sport pack asked for higher pressure and the non sport asked for something vastly different...
None that I've noticed so far, but I must admit I'm not concerned as I'm quite keen for these RFT's to be done so I can get a set of normal tyres, possibly slightly wider.
