Olorin said:Anyone?
Olorin said:Anyone?
FerdiBotha said:Olorin said:Anyone?
Search this forum, other forums and Youtube as it has been discussed many times over. Even if the info you find is aimed at N54/55, the concept is the same.
schalk320d said:Olorin said:Anyone?
https://www.bmwfanatics.co.za/showthread.php?tid=87860
Have a look at this thread
Olorin said:I need to know if this is reliable and I need to know if there is any advantage to going this route as opposed to software and downpipe.
I doubt a youtube video will give me the answer to that question hence I ask a question on the forum - you know, the guys who probably have tuned their cars and can answer in a non-BS manner.
If all I wanted to do was browse the net and Youtube then I wouldn't need to come here and ever ask questions. Clearly I see value in conversation.
Sherwin@xcede said:Hi there, JB4 is a piggyback. It intercepts certain signals from sensors in the engine, (like MAP, TMAP, fuel pressor, etc), attenuates the signal on those wires and manipulates it to show what it wants. This is then sent to the ECU.
It does work and it gets the boost up and some rudimentary form on richening up of the fuelling. No real active control of the timing. Neither of the valvetronic, VANOS, torque limiters, & too many others to mention.
But all of that is largely irrelevant if the car runs well. And the JB4 cars do run pretty well.
A flash is just a better, more complete, more elegant solution. And changing maps etc, it a bit of a gimmick. Once the map is right, you never need to change it. The exception id you you swap from pump to various exotic types of fuel like E40+ and need specific maps for those fuel mixes. Then swapping maps would be beneficial.
Olorin said:Thank you Sherwin for the informative reply! It answered my questions. Regarding the downpipe on a 320i, what can I expect apart from a power increase?
I'm not a big fan of the 320i engine note, I don't suppose it would improve on that?
NBN said:When you sell your car, you can remove a piggyback and recoup some cash. You cant do that with a Flash. Piggyback allows you flexibility in terms of returning the car back to stock, map switching, code reading and deletion. It also lets you add on additional components like meth or port injection .
Flashes are alot smoother and should ideally be tuned for a specific car.
They each have their merits, it all depends on what your intention is with the car and ultimately the power goals you have for your vehicle.
Olorin said:NBN said:When you sell your car, you can remove a piggyback and recoup some cash. You cant do that with a Flash. Piggyback allows you flexibility in terms of returning the car back to stock, map switching, code reading and deletion. It also lets you add on additional components like meth or port injection .
This is important. If I decide to want to sell the car in a year or 2 from now, I don't want to sell in a tuned configuration. I want it back to stock.
HIRRS-ZN said:Olorin said:NBN said:When you sell your car, you can remove a piggyback and recoup some cash. You cant do that with a Flash. Piggyback allows you flexibility in terms of returning the car back to stock, map switching, code reading and deletion. It also lets you add on additional components like meth or port injection .
I can hook you up with a jb4 and Downpipe and you will be making 200+wkw
Jb4 is easy to remove as well.
and you will be boosting at 23psiOlorin said:Does anyone have experience with Race chip?
https://racechip.co.za/shop/bmw-1/3-series-f30-31-34-from-2011/320i-184-hp-135-kw-1997-ccm.html
It's less expensive than the JB4, also seems to show a healthy power increase and can be removed if I need to service my car or sell it as stock.
