Ofentse said:I am sure he thought really hard about this before running with the idea, nothing for us to stress too much about :idea:
Naruto said:Mpower108 said:Naruto said:Nice power there :thumbs:
How's the delivery?
which tuner did you go with?
Is your car auto or Manual?
Auto.
Car was done by Chiplogic in Kyalami.
Nice :thumbs:
I'm sure you're loving the power gains :rollsmile:
Just do a research and see what's the maximum torque that those gearboxes can handle. I see the F30 328i produces 180kw @5000rpm and 350NM. Now I'm not sure if these cars share the same Gearbox, if not, have a look at this.
Enjoy your new found power.
Will make sure I lookout for you :rollsmile:
KyleNaidoo said:
Josh-ZN said:SP33DYV said:Josh, I am not sure you can get that much more power out of a 328i. The 320i and 328i has exactly the same motor, turbo, intake and injectors. So tuned, they should make the same power with the same software map, excluding any hardware mods. :dunno:
I sincerely hope that BMW do not pick up your new software, because they will suspend your M/P if they as much as suspect that it has been tuned.
I understand they share alot of the same internals, but surely the 328i has a better base for tuning than a 320i. There must be some internal differences that allow for the additional power in the 328i.
Just like a 1M has a better base than a 135i :dunno:
444YYY said:I like how seriously everyone takes motorplan these days!!! :thumbs:
Coisman said:444YYY said:I like how seriously everyone takes motorplan these days!!! :thumbs:
Ask Midas to post the repair bill on his 320i, and how much it cost to get it fixed, and how much he had to pay... O wait... Motorplan!!! :rollsmile:
Midas320d said:Coisman said:444YYY said:I like how seriously everyone takes motorplan these days!!! :thumbs:
320 d :=):
Midas320d said:Total was R23K :bangdesk:
P1000 said:Midas320d said:Total was R23K :bangdesk:
Wow, that is quite reasonable IMO.
Another thing, the claimed weight of the 320i is lower than that of the 328i, which is a good thing for acceleration, but it also indicates that there are differences. Like possibly brakes, driveshafts etc. The gearboxes are pretty much the same, well at least as far as torque ratings etc goes, even though the part numbers differ slightly.
George Smooth said:As a matter of interest the cars use the same pistons. The piston previously used on the 328 is now discontinued.
P1000 said:George Smooth said:As a matter of interest the cars use the same pistons. The piston previously used on the 328 is now discontinued.
Thanks. Yeah, I saw some posts about pistons being discontinued and now all the same, but did not go as far as to check if true. But if all this is so, why then only 328i power after a tune? I would expect 328i tuned power, since it is the same platform?
George Smooth said:P1000 said:George Smooth said:As a matter of interest the cars use the same pistons. The piston previously used on the 328 is now discontinued.
The car actually makes close to 328 flywheel power on the wheel and similar torque again on the wheel at altitude. Not all tuners max out cars capabilities creating a car that produces its power in all environments and conditions avoiding one hit wonders on the dyno and then on a hot day its fallen on its back.
As for your other devils advocate responses the checksum has been balanced to the same figure as the stock software. The fasta data triggers have been raised so nothing gets triggered as the DME thinks that its within normal operating spec. Homework has been done and equipment was not bought on special at incredible connection.:thumbs:
