1lum1nat1
Guys, I think I might be overreacting a bit. I need some info quickly.
When I put my key into the ignition & put it in the 2 second position, all the lights on the right hand side of the instrument cluster goes on & after say 2-3 seconds most of them switch of but the handbrake light stays on (obviously) aswell as the ABS & "check brake pad" light & on the left side of the cluster the EML light. After another 2-3 seconds they switch off aswell. Should I only be worried if they stay on?
Pic of the lights:
Pic of the lights:
