Tracking forum issues
Dees_13
Hi
I was battling to login on both pc and from my phone. Even resetting my password didn't work.
I can finally login again from a PC but not from my phone web browser. The error I get on my phone when trying to login is:
Authorization code mismatch. Are you accessing this function correctly? Please go back and try again
Salt
Did I maybe miss it, but I tried to change my avatar and it doesn't work. I removed the old one and now I've got none. I made it 100pixels max and smaller than 100kb but no luck.
NBN
RAArmstrong said:
Ya hi.
Report button doesnt work. There's sale threads floating about out there posted by noobs with 10 posts...
ditto...tried to report a post, report button doesn't work
Tinuva
Staff & Webmaster
NBN said:
RAArmstrong said:
Ya hi.
On PC (not mobile) right click and open on new tab on the report button.
Nella11
Good morning guys.
Yes directly after my post has been posted I would try to correct bad spelling for example...
Maybe it have something to do with me using a phone to do posts?
Thanks KPM 330 for your guys hard work and dedication to maintaining the site
SubLoaded
Resident Derailer
Nella11 said:
Good morning guys.
Open the edit button in a new tab, instead of just clicking on it.
It's one of the many bugs in the system. Click event isn't bound to the function correctly or routing is messed up.
ChefDJ
The @"Webmaster" mention function is not alerting via PM unless I'm the only one experiencing this.
Tinuva
Staff & Webmaster
Hi Chef,
That plugin was removed as it was no longer compatible with the latest MyBB.
The newer plugin, named MentionMe, integrates with the MyAlerts plugin, which you can see next to the User CP link at the top left which will have a number in () brackets to show the number unread alerts.
You can also view alerts here: https://www.bmwfanatics.co.za/alerts.php
Unless you have disabled this to alert you about mentions in posts, by default you should see that number go up each time there is an unread alert, including for post mentions and some other things. You can enable/disable what you get alerts for in your user control panel.
I know this is different from how the old plugin worked, but with change in versions the plugins also had to change. I really tried my best to keep as much of the original functionality with the upgrade.
Feel free to let me know if you have any other questions about this.
