ChefDJ said:
The @"Webmaster" mention function is not alerting via PM unless I'm the only one experiencing this.
Hi Chef,
That plugin was removed as it was no longer compatible with the latest MyBB.
The newer plugin, named MentionMe, integrates with the MyAlerts plugin, which you can see next to the User CP link at the top left which will have a number in () brackets to show the number unread alerts.
You can also view alerts here:
https://www.bmwfanatics.co.za/alerts.php
Unless you have disabled this to alert you about mentions in posts, by default you should see that number go up each time there is an unread alert, including for post mentions and some other things. You can enable/disable what you get alerts for in your user control panel.
I know this is different from how the old plugin worked, but with change in versions the plugins also had to change. I really tried my best to keep as much of the original functionality with the upgrade.
Feel free to let me know if you have any other questions about this.
