Hi all
I can report that the E39 is back on the road. The water leak was quite serious and a new radiator was fitted. The second time I have had to to that. Such is life with Bavaria's finest cooling systems. It also needed a new battery - seems like the stinking tracker unit killed it while parked.
I used the car for the office run today. It was a bit of an adjustment to drive a stick shift again but all is well.
Er, not quite. There are still some problems. I am looking at a triage to fix them. Here is the bad news:
- that ABS controller is still a zombie (it comes back to life for a short while when it is very cold but dies as soon as the engine heats it up again)
- there is a nasty oil leak or two
- while parked in the garage, something fell on the rear fender and there is a small dent to show for it
- some weirdness on the dash regarding blown rear bulbs or (more likely) broken wires in the loom going into the bootlid
- broken tail light
- front inner wheel liners in a very sorry now state
- driver's door rubber well past its best days
- a few unsightly scratches on the rear bumper
- gator around gear lever refuses to stay in place, the plastic thing holding it keeps jumping out
- SII says it is time for an oil transfusion
At least the tyres weren't flat spotted while the car was parked. I did move it around from the time to time to prevent this. Also, the fuel in the tank did not turn into wood varnish.
The decision is now more or less unanimous that E46 will go when the big 5 is all sorted. I am also looking at fixing the very worst problems on that before it goes. The left front window mechanism is
kapoet and it also needs an oil change.
When all that is done I can attend to the E32. She is not currently mobile as she needs a new battery. I seems like I am on a car battery buying binge this year.
