moranor@axis said:lol i thought you were going to ask about putting some subs in the boot :rollsmile:
your rear pads could be low and moving in the calliper when you reverse and apply the brakes... try see if the noise only comes when you brake in reverse...
if it does only come when you brake then next time you reverse you should try stopping with the hand brake... if there is no noise with the hand brake and a noise when you use the foot brake then its definitely the pads![]()
Philip Foglar said:moranor@axis said:lol i thought you were going to ask about putting some subs in the boot :rollsmile:
+1! Common issue! :thumbs:
abmi0000 said:Will let you guys know if the noise goes with the replacement.
By the way, I have like 4200km left on the front according to the on board. Will I be able to reset if the sensor hasn't triggered as yet since I need to sort the vibration on the discs out and the front pads are taking forever to get finished.
Yeah yeah, I am prepared to sacrifice some pad... :=):
moranor@axis said:abmi0000 said:Will let you guys know if the noise goes with the replacement.
the e60 tells you how much pad you have left?
its normally the rear pads that make this noise though...
abmi0000 said:moranor@axis said:abmi0000 said:Will let you guys know if the noise goes with the replacement.
Umm yeah, they do. I definately have a noise when I lightly tap on the brake and then it isn't there again if you try and simulate immediately thereafter.
Philip Foglar said:With the E90 it seems to be a known issues on some cars. You brake when going forward after having to brake while reversing, like in parking lot etc, and you get this thump sound. It's an annoying and embarrassing noise in most cases. It's usually (or so I understand it) the slight amount of play in the calliper that allows the pads to shift in the forward and then reverse directions. So with older worn pads this also makes sense.
moranor@axis said:resetting e60 sensor
seems the e60 has two sensors one for when the pad is finished and the other for measuring how much pad is left![]()
abmi0000 said:Philip Foglar said:With the E90 it seems to be a known issues on some cars. You brake when going forward after having to brake while reversing, like in parking lot etc, and you get this thump sound. It's an annoying and embarrassing noise in most cases. It's usually (or so I understand it) the slight amount of play in the calliper that allows the pads to shift in the forward and then reverse directions. So with older worn pads this also makes sense.
I seen on some car programs that guys actually layer the outside of the pad with copper grease to eradic this. Anyone ever try it?
