The Famous E46 M3 clunk
ac427
A lot of the time it it the CV joint at the diff end that is the issue. If you are going to replace the other joints you can just buy the prop which come with all the joints anyway. It's probably very expensive now but it was reasonable when i did mine. Also, it is the only way to renew the UJ in the middle of the prop if it is worn.
