Temp gauge
Rafatak
Good morning fanatics
Please can you help..I have an E46 330i manual 2001.
I did a coolant flush and decided to neaten up the wiring in the engine compartment while I had the space and time.
When I turned the key to the 1st position my temp gauge when straight to the red without the car being started.
Did a diagnostic test. Error code 10TKW but could not find anything on the net related to that code. Car was running perfectly before that.any help will be appreciated. Thanks in advance
Tinuva
Staff & Webmaster
Seeing as you neatened up the wring, start with the wiring to the coolant sensor.
Also, what exactly did you do with "neaten up the wiring" ?
Rafatak
thanks for the reply
the wiring was basically intertwined with each other so i basically rearranged them to flow neatly.
i didnt open any sleeving or anything of that sort
