Sankekur
So this morning when I got to work I press the button to close the sunroof, the sunroof closes to about three quarters way closed then it stops and goes back a bit, press the button again and it closes properly.
So I open it again, and then press the button close it again, same issue except this time it doesn't want to close properly at all, it closes a bit stops then opens a bit again every time I press the button to close is.
I remember reading somewhere (or someone told me, can't remember) that the sunroof senses the load if it is closed more than halfway, probably for protection of both the user and the sunroof. Either way I pull slightly forward on the sunroof and press the button to close it and I get it to close properly.
So it would seem that there is to much load on the sunroof causing it to not close properly (or it might be something else), either way it looks like I will be removing my sunroof so I can clean and maybe re-grease all slidey and movey bits, maybe these bits have to much resistance in them causing the increase in load.
Anyone else ever have a problem like this, and have any info to share?
