Sump gasket replacement on 2007 E90 320i
DnG
Hi Fanatics,
The E90 is slowly leaking oil from the sump gasket. BMW quoted almost 3k for replacement and while I understand that its a labour intensive task and the suspension needs to be loosened, I still find the pricing quite high.
Car is off motorplan and I really don't see the need to take the car to BMW anymore.
I would appreciate any pointers on who to use for the repair work in and around Joburg area?
I have previous experience with BW Auto and Autospot.
Thanks in advance.
Iceman007
Well I paid R2000 for an 318 e46 sump gascket replacemant at an BMW agent. If you dont have a lift I would not recomend it. It is a bit of a job for I was there while they did it. I wont charge less than 2k for the job.
DnG
Yes I believe its a bit of a bitch to do. Will just take it to Autobahn get it over and done with. Cheers
npower
Damn N46 engine got a reputation for oil leaks.
Had to change sump gasket, along with tappet cover and oil filter housing gaskets twice in 20k km:argh:
Once under motorplan and second time came to about R 5 000. Despite my protestatation to stealers why gaskets should fail in such a short space of time and distance, I still footed the bill. :cry:
