Hi....
Dont know if you guys know the epping turn-off on Jan Smuts that takes yo past the market. I take the turn off and in automatic mode, as i come down the bridge with the Market on my right and the car start vibrating as i try to poic up speed. Like in 1st and second gear in "misses". then all the way down to Vanguard drive it misses, i stop and pull away and seems to miss but when im at 60 km/h it stops.
I get home, put the car in drive and reverse and still does the missing thing. I thien switch off. Check oil and water. All good, no leaks. Car didnt over heat. Then 5 minutes later start the car and in "drive" and "reverse" no missing. Pull the car out stop, pull away, stop, pull away...all good. I then gun it down a straight and back, all good.
No missing. Checked oil and water again...nothing. Im confused. Could it be that the car couldnt gear up/down quickly enough causeing this?
