Raybimmer
If a compression test is done on a warm engine and the values written down you can look at the variation between cylider values and the readings themselves . Eg if cyl 2 is 800 and cyl 3 is 1050 and cyl 4 is 700 then there is a problem . but also if all should be 1050 and they are say 700 then all rings or bores or valve guides are worn . If you now drop a teaspoon of oil into each pleghole and redo the comp test and you get higher readings then the oil has sealed the bores -rings or bore wear is the problem . If the wet test values do not climb then the head is the culprit - burn valve , seat damage or worn guide ( valve not on seat in same place each time ) .
Good luck .
Good luck .
