Speedo Cruise not working
Dean ///M
Limited Profile
Can someone tell me what could be the cause of this on my Z4MCoupe? Only brakes was done recently at the dealership.
Clownshoe
This is uaually an easy fix. There are two switched on the pedals, one on the brake, one on the clutch. If iether of the pedals are not touching these switches the cruise will not work. As you have had brake work done i would hazard a guess the travel on the brake pedal has changed. These switches are adjustable.
MikeR
go punch someone at the dealership - it might not sort the problem bu u will sure feel better and they wont do it again. :thumbs:
Dean ///M
Limited Profile
Thanks will check up on this one.
Lol. Can't do that he's a good buddy of mine. Does his best on my cars but it is frustrating without it as you as want to tramp it.....U know how a Z gives you that urge...
MikeR
:rollsmile: all the time.
I had my breaks done last week - all round new disks and of course pads and everything is fine, let them look again it might just be a sensor not clipped in right.
zaleonardz
If a sensor was out, you would have an ABS light or a pad wear light.
Could easily be a clutch pedal switch, it shares the brake pedel switch, so if that was faulty your brakes would be on all the time.
Pop past for a diagnostics bud, i can sort you out quick quick im sure :p
