loskop said:Hi Guys
So after changing turbos/PCV valve/Valve cover gasket my car is still smoking on deceleration/braking.
Seems to be getting worse. Looks like there could possibly be oil in my exhaust pipe. Could this be valve stem seals as this is my next repair I have planned.
husaindindar said:loskop said:Hi Guys
Suggest doing a compression/leak down test before popping the head off for stem seals.
Stem seal are uncommon on these engines. Most probably something else.
loskop said:Hi Guys
So Seems like christmas came early.:smilebounce:
For the last 2 days my car has not smoked once.
How is this possible??????
Perhaps PCV system was clogged?
Maybe a stuck oil ring??
All i can say is im very happy at the moment.
Merry Christmas guys
:ty:
rsgordini said:loskop said:Hi Guys
:ty:
Nice.. what engine btw
Taufeeq786 said:Still want to know what caused this and how did it suddenly go away?
Mine is still there and il be doing the PCV soon
Shuaib1 said:This smoking is making you scratch your head the while time. Did they check the car out or didn't you take it after it stopped?
Woodies said:Both exhausts smoking? If only 1 side, it’s going to be the turbo seal I’d guess
