Smoking on Idle/Deceleration
loskop
Hi Guys
So after changing turbos/PCV valve/Valve cover gasket my car is still smoking on deceleration/braking.
Seems to be getting worse. Looks like there could possibly be oil in my exhaust pipe. Could this be valve stem seals as this is my next repair I have planned.
husaindindar
loskop said:
Hi Guys
Suggest doing a compression/leak down test before popping the head off for stem seals.
Stem seal are uncommon on these engines. Most probably something else.
loskop
Hey man
I have done a compression test and that passed.
Valve stems will be done without popping the head off.
So far I understand it Valve stem seals are common on the 6 cylinder engines. I have 170 000km on the clock.
husaindindar said:
loskop said:
Hi Guys
loskop
Hi Guys
So Seems like christmas came early.:smilebounce:
For the last 2 days my car has not smoked once.
How is this possible??????
Perhaps PCV system was clogged?
Maybe a stuck oil ring??
All i can say is im very happy at the moment.
Merry Christmas guys
:ty:
rsgordini
loskop said:
Hi Guys
:ty:
Nice.. what engine btw
loskop
N54 Engine.
rsgordini said:
loskop said:
Hi Guys
:ty:
Taufeeq786
Still want to know what caused this and how did it suddenly go away?
Mine is still there and il be doing the PCV soon
loskop
Guess What - Smoking started again.
Now comes the catch
I took it to get checked. The guys said i need to remove the JB4 for them to diagnose the car. Car stopped smoking again. So stopped when JB4 got re-fitted - Week later smoking
Stopped smoking again when JB4 got removed.
How the hell is this possible???
Shuaib1
This smoking is making you scratch your head the while time. Did they check the car out or didn't you take it after it stopped?
loskop
The car has been checked by BMW and 4 other places.
No one has a straight answer.
Woodies
Both exhausts smoking? If only 1 side, it’s going to be the turbo seal I’d guess
husaindindar
Hey there bud.
I feel your pain.
Just a thought. Is the oil coming up short?
Reason why I ask is that maybe its not oil causing the smoke. Maybe over fueling?
If no oil short, then no oil causing the smoke.
Taufeeq786
if you still scratching your head contact Riyaan 079 789 4835. I replaced PCV and it seems to have fixed the issue i hope lol... Lets see how it goes.
evnmopwr
Maybe i missed this but what color is the smoke??
bluish? White or Black..
how regularly you checked your oil?
you having to top up often?
Also, Have you removed your plugs???
If you remove them, that will give you an idea whats going on..
smell them ..
I see you done a compression test but have you down the Leak down test too??
