Philip Foglar
My current PC is as follows - bought in late 2009:
MSI P55-GD65 130W DDR3 GB LAN ATX S1366MBD
LG 22X DVD WRITER SATA NERO 7 + FACE
SIGMA AEGIS 0.8MM BLACK - NO PSU
PROLINE 600W ATX12V V2.2,12CM FAN, NON PFC
MSI N260GTX-T2D896-OC 896MB DDR3 448BIT x1
Seagate Barracuda 7200.12 1 TB SATAII 32MB 3.5" x1
APACER 2GB DDR3 1333MHZ DIMM PC3-10600 x2
INTEL i7 860 QUAD CORE 2.80GHZ 8MB 2.5GT S1156
Gigabyte GM-M8000 Laser Mouse with Ghost mouse pad
My old PC which still runs, believe it or not, is a circa 2001 rig comprising:
AMD Athlon Thunderbird 1.333GHZ
Asus A7V-133 PC-133 SDRAM with a total of 640MB RAM
Leadtek Geforce 4 4200ti with 128MB AGP
80GB IBM Deskstar ATA100 IDE 3.5" HDD
160GB Western Digital ATA100 IDE 3.5" HDD
250GB Western Digital ATA100 IDE 3.5" HDD
AOpen CD writer and AOpen DVD writer IDE
Logitech Mouse Man Dual Optical Mouse
Older graphics cards used were, the horrible Riva TNT PCI (not even AGP) 32MB card, then a lot better, the Gigabyte Geforce 2 Pro 64MB AGP. Also had an old IBM Deskstar 20GB ATA100 IDE 3.5" HDD...
This old PC still runs but really needs to be retired! Has a problem with cold bootups due to the power supply and I suspect one of the WD HDDs, so to get it up and running you have to start the machine minus the HDDs and then individually plug them in, then all is fine. Used to be able to put the machine into standby so that at least the CPU and HDD's could be powered down, but now coming out of standby seems to trigger this above problem. Thinking about it, that machine is literally 11 years old later this month! And as per the Max Payne 3 thread, this was the machine that I obviously used for it! :bravo:
