Hi, you can do the following trick and see if this works for you.
When getting into your car, put your foot on the brake pedal (yes the brake and not clutch) and then press the start button as if you were going to start the car, wait for the service lights to go out and then hold down the km reset button that is at your speedometer, hold it in and wait for the brake sign to come up on the display. Then release the reset button at the speedometer, now use your bc stalk up and down dial to scroll through the menu until you get to the brake sign, remember there is front and rear, so ensure you pick the correct one by pushing the stick on the stick (don't know what you call that thing but you normally press this button up and down if you cycle between the kilometers left over based on your fuel, average km per liter and then nothing in the center screen between the dials.
So do it like this:
1. Climb in car and put your right foot on the brake pedal instead of the clutch pedal.
2. Press the start button until all lights are on, on the dash.
3. Wait for all the lights to go out, the service light will be the last one to go out. Once it goes out, then go to 4.
4. Press and hold the reset little stick thingy that is next to your speedometer clock on the dash. HOLD IT
5. The car will start and cycle through a menu again and you wait till it gets to the brake sign, then release the stick thingy.
6. Now go to the BC stalk stick and use the up and down selector on the stick to cycle through the menus until you reach the relevant brake, rear brake picture in this case.
7. Now press the BC button on the stick inwards towards the steering wheel, the screen will display reset. Press it again and HOLD IT.
8. The ---------km will change and you will see 25 000km if I am not mistaken.
9. Take your foot of the brake pedal, push in the start button to switch car off. Take key out, open driver door, close it and then insert the key again into the key hole.
10. Start your car and see if the error is still there, it shouldn't if this was done correctly. Just start from no 1 if anything goes wrong, don't warry cant damage the car this way.
Hope this helps and it is the way you reset all of the service indicators on your car :rollsmile:
Simple me, I didn't read the whole 1st section of this forum. The reason it is displaying the --------km is because of 2 things, either the reset of the 10 steps above wasn't done correctly or the worse part is the (and I believe it to be this) the new brake sensor has been installed incorrectly or is a faulty sensor. (disconnect the sensor in the wheel arch and reconnect it and then reset it via the 10 steps and see if it disappears, might be a bad or dirty (dusty) connection)
