Service for E60 V10 M5
Vee Ten GP
Can anyone suggest a GOOD BMW specialist in the Fourways/Randburg area to take my E60 M5 for an oil change and brake fluid change service. Cedar Isle BMW have done a good job on the car in the past but they are a bit expensive as I am no longer working.
graan13
Not sure how much the BMW quote would be but you can try Evolution 2 Motorsport in Kyalami. I use them and have done for many years. BMW specialists. They dont take on many cars, maybe 1 or 2 a day for general service. They only use OEM and are very thorough, won't say they are cheapest but workmanship is top notch.
Unit 3 | 6 Forssman Close | Barbeque Downs | Kyalami | Tel: +2711 466 1266 | Fax: +2711 466 1267
Speak to Alec (owner), Gavin or Warren
Nikhil
Personally i would use Tunetech they literally have V10 M5's & 6'S Lined up for maintenance or major work.
zaleonardz
So just because its a V10 does not mean a oil change is that much more compliated…
If you can change the oil on a 318 you can change the oil on a V10...
Brake fluid flush can be done with CBF Randburg, but is also a fairly no brain procedure...
Rotinaj
buy the stuff you need and DIY it if you have the tools. It's not hard. I just dislike servicing the M3 because it's a pig to get into the air without a 2/4 post.
Neven
BMW Car Club Member
I would highly recommend Tune Tech. Have used them only once so far on the E60 M5 but will definitely keep maintaining her there.
FiRi@Rennzport
Peter from axis engine works, can also assist here. Check his vendor section out.
Sent from my CLT-L29 using Tapatalk
Nikhil
This or even forgot to mention Ross Duncan in Midrand
Dhp507
Jakkie2207 said:
Has anyone tried GP Motor Works in Ferndale?
Last time I used them for a service on the Diesel, overfilled the oil by a liter and did not put the items they removed to service the car back correctly, i.e loose and mis-aligned
