To run it in, use high load and low revs ( < 4000rpm) till 2000km and thereafter you can start hammering it.
If you rev it high when still tight (and it will be) it generates a lot of heat locally on the skirts of the pistons causing it to expand more than it should.
It then scuffs = make contact with the sleeve. If you are really tuned finely into how the car should sound, you will hear that it then has a slight knock when cold.
Now you will not notice this easily and it will not break down quickly, but it will always be a little down on power and it will for argument's sake only last 200k where it could have gone to 300k.
I don't understand the mentality of hammering it immediately. What on earth could be bad about taking it easy the first 2000km?
And as I said - use high load. That means lots of flat out acceleration, but don't rev beyond 4000 rpm.
