HELLAS said:
Looks like the 3 liter diesel turbo is made a bit stronger then. One colleague of mine's 320d is on 204000km without any sign on turbo failure (Or at least the turbo has not been done yet)
I removed the swirl flaps but simply removing the plates from the spindle.
As for possible signs: I had it where the car would smoke EXCESSIVELY on cold mornings. I usually blamed this on a malfunctioning EGR, but it could be oils bypass on the turbo? Either way, as time goes by, you think of the events before the turbo failure and slightly more smoke than normal under heavy acceleration may have been present. Also an indicator?
The turbo whislte I had before the failure is still there after the replacement, so I won't really read anything in that.
I replaced my 530d turbo about 6 weeks ago, already done about 3000km on the new turbo, I will post some pictures soon, the old turbo had 225000km on it and the only thing that broke on it was a fracture of one of the turbine blades, it came out under boost and embedded itself in one of the two parallel cats on the 530d.
The turbo had very little wear on the bearings , and the shaft was still great, Turbo exchange quoted me around 3000 for the parts and included a high speed balance , I am going to do that soon and keep it as spare.
The turbo was a GT2556V.
I bought the new Garrett one , exactly the same stock code , from Engine Parts in Bloem for 8000 bucks. The stealers ask 17000 for exact same part, crazy man!
I took out both the cat innerds at Noise Boys in Bloem by cutting two small doors in the cats and then hammering all the cat sht out with a big screwdriver, afterwards just welding back the door flaps, job done!.
The turbo now could be heard ever so slightly, but she pulls lekker strong with the new blower and very little back pressure.
I also blocked off the EGR and took the valve innerds out from the valve body.
I installed and silver soldered in two welch plugs right at the outlet to the egr and also on the top next to the valve body.
The car never smoked and still does not smoke, after the turbo replacement and decat, only slightly under hard acceleration, but thats normal.
I also reconditioned one of the injectors, for 2000 bucs after replacing it with a new one for 5000 rand at the dealers, the old one only needed a new tip and they gave me a warranty as well as proper report of the before and after flow levels. The old injector had suddenly started to give problems with low flow and the engine vibrating and missing.
