Gizmo said:What is wrong with the current engine?
RasX5 said:True that!
Try the following guys:
Sorry dont have numbers, but you should find them on Google...
Wannenburg and sons
CR Auto
Bemows
All these boys are in and around PTA, bemows would be be your best best!
If he doesn't have, he'll point you in the right direction!
Hope you come right!
RasX5 said:There is no way n my opinion that parts alone can cost that!
If its bearings and pistons with rings?
Easy go to QEC they in pretoria, find a set of bearings!
And go get aftermarket pistons from arais or one of those boys!
Get any reputable engineering shop too do the work! Van der Linde imho.
And see where your bill sits then!
Pho3niX90 said:Gizmo said:What is wrong with the current engine?
The oil pump failed, and apparently the pistons, sleeves, crankbearings, chain guide are all shot, and the bill to repair everything is R120K. Its currently in alberton.
moranor@axis said:I think Racing snake on the forum might be keen to take this on![]()
