REDUCED POWER
DSC
HI
STANDARD BMW 135I N54 . UNDER WOT IT KEEPS GOING INTO LIMP MODE ND LIGHTS UP DASH BOARD WITH REDUCED POWER .
CODES : 0030FE
AND 3100
ANY IDEAS MEMBERS ? I BELEIVE THIS CODE IS FOR OVERBOOST AND FOR LIMP MODE . WHAT CAN CAUSE AN OVERBOOST SITUATION IN A STOCK CAR .
WHEN CAR IS SWITCHED OF LIGHT IS GONE AND ENGINE HAS POWER AGAIN UNTIL THE NEXT WOT .
Twinz
Forum - Support
Take the car to someone that knows these cars to assist you. Its hard to troubleshoot a car remotely without a datalog but someone that knows these cars can check the obvious culprits...e.g. boost leaks...broken chargepipe...etc
An overboost condition/boost spikes/boost overshoot can also be triggered by a huge boost leak or general boost control issues on the solenoids or vacuum lines.
MikeR
:fencelook: is the car def stock ? are you the first owner ?
check all breathing pipes (rubber ones)...they get soft with age.
Iceman12596
Agree 100% on this
@DSC
Take the car to Chris at CCD, their work is topnotch and they BMW Specialist.
rsgordini
1.Vacuum seals.
2.Boost leak.
3.Charge pipe crack.
4.Waste gate broke..
I think no1 is most likely...
DSC
Hi
I have checked no boost leaks , no cracked pipes . However on the right side solenoid there is like a black cap that is broken off revealing a 3rd nipple on the solenoid . maybe this is the issue ?
Where are the vacuum seals located ?
rsgordini said:
1.Vacuum seals.
2.Boost leak.
car is def stock . I beleive its the 240kw 135i . some of the rubber pipes do seem soft . There are no leaks or visible cracks on the vacuum pipes
i believe boost leaks throw off a fault code as 0030EE . which shows under boost targets . so I doubt there can be leaks.
Is there any BMW SPECIALIST in durban whom can help ?
SubLoaded
Resident Derailer
DSC said:
Hi
rsgordini said:
1.Vacuum seals.
2.Boost leak.
PM sent
