Red Handbrake light on E90 '10
Aadz17
Hey guys so my red handbrake light came on around the same time my car needed to go for a service, got the car serviced and rear brake pads were finished so replaced the brake pads however the red handbrake light still seems to be on my dash ..
Please advise on the matter
Thanks guys
Lizzard
Morning,
You will need to reset the indicator on your car.
Try this method:
Step 1 - Insert key into slot
Step 2 - Press start/stop button without depressing clutch/brake and wait for the service reminder to disappear.
Step 3 - Immediately after service reminder goes out, press and hold the odometer reset. After 3 secs a warning triangle will appear, keep the odo. button pressed and after another 2-3 secs the Oil can will appear. I f you hold it too long (10 secs in total) you will overshoot the runway and some German writing will appear giving the software level/ can bus etc. of the car. Go back to the beginning and start again.
Step 4 - You are now in the service menu, use the toggle switch on indicator stalk to scroll up/down through the various service items.
Step 5 - When you have the item you want to reset showing, press the BC button on end of indicator stalk. Reset should now appear in the display. Press in and hold the BC button for 2-3 secs and a clock will start whirling around and hey presto, its done
Step 6 - You can now either scroll up/down to select another item (as in step 4) or you can press the start/stop button to exit.
Hope this helps :rollsmile:
