a1exander said:
The replacement sensors have the following coloured wires
Balck-Grey-White-White
Black is power
Grey is negative
Whites are heat wires
The car has the following colour wires
Black-power
Brown negative
Yellow
Green
with yellow and green being the heat wires.
Right bank wires were wired correctly
Left bank were incorrectly wired in as much as they connected the yellow wire as negative to both sensors.
So the car now idles ok and is not throwing up errors and multiple misfires.
In the process it has lost it throttle adaptations and the accelerator pedal is not communicating with the throttle body so it is now in limp mode and will not respond to throttle inputs.
Next chapter..............................
Anyone know how to reset the throttle and pedal please let me know as google is not your friend in this instance.....
OUCH OUCH OUCH !!
This sounds like the learning experience I had in my shop last year
to summarize
1)VW Polo with cracked manifold casting, new manifold from agents R5000+
2)Elected to rather do branches (Viper)
3)Supplied branches didn't have the same o2 sensor fitting as the probe, only discovered by technician after the entire system had been installed
4)Ever willing exhaust technician trying "to please" cut off the O2 probe, and walked over to Goldwagen, to purchase a new probe, but with a different thread and taper, to match the new branches
5)as it turns out it was a Toyota probe we purchased
6)Wire colour coding was different to the existing wires
7)lack of technical knowledge in this respect, attempted to re-wire the probe and installed.
8)once the work was completed, customer left the shop, but drove about 1KM then the car went into "limp" mode, so he "limped back to the shop.
9)I then was made aware of the problem. told them to remove the branch and return to Viper to get a branch with the correct VW adaptation for the O2 sensor
10)remove and re-fit the correct branch
11)remove the toyota O2 sensor and re-install the VW O2 sensor
12)Car still in "limp" mode, accelerator pedal not communicating with the throttle
13)Install brand new VW O2 sensor......problem persists
14)relocate vehicle to the VW CLINIC behind us
15)New computor box fitted, errors cleared, ..car OK
it turns out that during the crossed wires when fitting Toyota O2 sensor, it blew some delicate circuitry, according to the owner at VW CLINIC, 5 volt and 7 volt circuits blown within the computor
Cost of Branches +/- R1500
Cost of sensor (times 2) +/- R500
Cost of repairs at VW CLINIC R3800
Customer charged R3200 initially--rectification was on our cost
Loss R2800
so I learnt, so we learnt
Hope you get your issues sorted soon
