a1exander said:
Gizmo said:
Why won't the std rings work if you keeping std bore? Measure the ring gaps of the rings in the new sleeves, if the ring gap is too large then get oversized rings and re-gap them.
I am trying to research the material used in alusil bores as opposed to spun iron bores.
By way of example the M88 and S38 use chrome molly rings and the M62Tu stainless as I have been told.
Equally a stainless ring is to aggressive for a spun iron bore and although it will seal it will wear (the bore) quicker over time.
I am trying to make sense of all that so your input would be most welcome.
So the idea is to use a "standard ring" but not necessarily a BMW v8 ring.
I am glad you are researching the materials as the stock pistons are also specially coated in the stock application and there are a number of considerations.
1) Nikasil uses steel coated aluminium pistons to prevent same metal running on each other (cant be done)
2) Alusil uses nickel coated aluminium pistons
These V8's, as I have read in technical documents used aluminium primarily as part of the design for cylinder wall heat dissipation ability and to allow much tighter bore clearances than typical. With steel liners you will have to open up the clearances.
With the steel liners the engine will actually sound different (I have heard)
There are three ring materials that are typically mixed, these are indicated but three numbers such as 777 or 776 etc but if you use steel liners it will make it easier just the top ring will probably need to be chrome or nitrided due to the amount of heat that is generated, moly would not the best choice. Middle and oil ring you can use anything you want including cast iron for the middle ring if its a steel liner.
I know the combustion in these engines generates enough heat to require special material exhaust valves so this would apply to the top ring as well.
I know KS sells Alusil liners that would allow you to use the stock pistons if you can get hold of them
