Rear brake pads on E46
Rapido WP
Can anyone confirm that I would be correct in assuming that the rear disc & pad sizes are the same for 318 through to 330?
Philip Foglar
Check RealOem, but for ATE pads (and disks) try Midas in Goodwood, their prices are very good!! :thumbs:
Hellas
You are probably buying in bulk, Rob. Or at least get fleet discount :)
Yup, only the 330 and M is bigger.
Iceman007
No the rear brake pads and disc's differ on 318 from year models aspecially from 2001 till 2002. You can remove the disc and pads and take it with you as sample or measure the discs outer diameter
Raybimmer
My info is ATE rear disc for 318i 1999 model is part number 110-0202
The 330i and 330d had part number 122-0209 .
You can measure the thickness and diameter and check the pad number if you do not take them off as samples in order to see if the new ones are correct .
Good Luck .
