HISTORY
1st maintenance visit to Leo Haese:
1. First Service
2. Fanbelt squeal on cold start.
3. Metallic vibration sound between 1800-2500RPM.
4. Loose airbag cover. (Left Rear above "parcel shelf")
5. Creaking door rubbers when going up driveways, rough road surfaces etc.
RESULTS
1. Oil was nice and clean, book stamped etc.
2. Squeal on cold start worse than before. This lasts for about 2-3 minutes from a complete cold start. (For example: When the car stood overnight. Otherwise it seems fine.)
3. The vibration was gone when I collected my car, but is starting to re-appear. At the moment the vibration is less than before, but getting worse as mileage increase.
4. The panel is not correctly aligned and the little "airbag" cover damaged. It looks like they removed the cover with a screwdriver, causing the plastic to become damaged.
5. The door rubbers were lubricated and resolved the problem for a few days. Unfortunately the creaking has returned.
2nd maintenance visit to Leo Haese:
1. Fanbelt squeal on cold start.
2. Metallic vibration sound between 1800-2500RPM.
3. Replace damaged airbag cover.
4. Creaking door rubbers when going up driveways, rough road surfaces etc.
RESULTS
1. All pulleys replaced and problem fixed.
2. Vibration fixed.
3. Part on back order, they will let me know when it arrives.
4. All door rubbers lubricated and was told the after market window film is causing the creaking. Nothing else they can do.
THEN
I opened the bonnet for routine cleaning and found the cloth. I was REALLY pissed off and logged a complaint with BMW SA.
After my complaint to BMW SA I was contacted by Leo Haese Hatfield.
I was told that the cloth was installed as a temporary fix and that the OEM brackets to fix the problem was ordered and I have an appointment for 14 June to have this fitted with the airbag cover that was also on order.
My opinion: I was never informed of any scheduled maintenance on 14 June or the fact that they installed a piece of cloth as a "temporary" fix. If there was maintenance scheduled on the BMW system I would have received a SMS like I always do. I think they're trying to cover up this whole situation by claiming I had an appointment and that the fix was temporary. I do no believe that the parts (brackets) were ordered or the maintenance scheduled as they claim. They cannot explain why I was not informed of this service date.
I received several calls from BMW SA saying that the "cloth fix" should never have happened and it was not up to BMW standards. They asked me to keep them updated on how I am treated by Leo Haese and how this issue was resolved.
