Hi guys, I have a e36 318is and recently while driving , at random moments i would loose power steering , and after some time itl start working again... anyone got any ideas? thanx
Is the power steering fluid level ok?
Condition of the belts and tensioners? If the belt or tensioners are worn it could be causing them to slip from time to time which would cause you to lose power steering.
Condition of the pump?
Had the same issue not too long ago and when i brake hard there used to be a strange noise......turned out the power steering fluid was low, topped it up, working 100%, noise and all gone!!
Had a similar issue with my Jetta 3, only happened in wet weather though. Turned out to be a loose belt, combined with the wet weather it started slipping. Really scarry when going around a bend cause u would have no power steering and all of a sudden it would come right again.
Yeah pump, belt, oil and tensioners check all these. I don't know about you guys but I'm gulity of this. I didn't ever change powersteering oil. I need to do this ASAP.
