Hey Everyone,
Apologies for the long story. If you KNOW the answer to the question, you might not need to read it all. I really just want to know what the correct ATF fluid is for my power steering system-- it REALLY shouldn't be this hard.
Currently it's a very dark, chocolatey brown 🤨
I've been trying to flush my power steering in order to resolve a humming noise in my engine bay. I knew that some models use CHF-11S and some ATF, but the car wasn't with me to check when I ordered.
I called Goldwagen and they said I needed CHF-11S. Bought 2 litres which they promptly delivered. Later that evening after the wife got home, I went to do the flush and saw my cap said ATF ONLY 🤦♂️
Stopped in at Goldwagen the following day and told them I needed ATF. A gent behind the counter said I needed "A320"-- Goldwagen's code for Febi 02615. I trusted them again.
Got home last night and opened the bottle and saw a clear fluid. Febi's site says 'yellow'. Checked the bottle and Febi's site and saw that they'd given me hydraulic fluid, which is obviously not the same as ATF fluid.
Called them again this morning, after I'd punched the BMW part number for the fluid, obtained via RealOEM, into Febi's site and it matched it to Febi 08971, a red fluid. They didn't have but ordered it for me.
I've subsequently dug deeper on Febi's site and see that they suggest a different fluid for the 135kw version of the N47, which is in fact a clear/yellow fluid called Febi 34608.
Can anyone provide some insight?
Different fluids obviously cannot be mixed. Right now I'm leaning towards just using what I've ordered, but doing a complete flush, as opposed to the easy flush of just remove with syringe/fill to top/repeat until it's clear.
Thank you, as always 🙏
